Unsullied_Spy
Unsullied_Spy's Avatar
01.20.2009, 08:41 AM
Steel pinion with steel spur will make noise, especially coupled with a motor like a MedUsa that has such a powerful magnet (hence the notchiness in it). Perfectly normal.
What are your temps like after the run? If your temps are all good you could step up a tooth or two if you want.
The steering servo is sufficient if it works for you. If it turns too slow get something with more torque and a faster time. I have a Hitec HS-985MG and it's more than enough servo for my Hyper 7.
Settings on the MMM are up to you, but you could turn up the punch control a little to keep amp spikes down and make it more drivable. I usually run normal timing on 4 pole motors, lowest on 2 polers.
FG101C
01.20.2009, 09:57 AM
I've found that for some reason the Losi pinions are a little quieter than the other brand pinion's.
