eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
01.25.2009, 11:59 PM
thats karma for u ben
he decided to rape my hyper when it only had 3 wheel drive, and flipped it over, then drove over it multiple times... then he ran into a light pole abut a minute later and broke the arm! btw it wouldve been cooler if u put the rx under the mmm on the plate or put the plate at a 45 degree angle
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
brushlessboy16
brushlessboy16's Avatar
01.26.2009, 07:43 AM
Right now the switch for the MMM is on the underside of plate. I wouldnt put the rx down there in fear of wires coming into contact with the pinion/spur.
just hope it will fit under the new body..
florianz
01.27.2009, 06:00 AM
you shoult connect the mount with the chassis, with a bracket:
like that you have
-no flex at all
-the chassis turns into a heatsink
its quickly done and it works. I have two mounts, one for a bigger motor (kb45xl), all alu in L-shape, and one made of alu and carbon for a 36mm motor, which ist definately stiffer. the one for the kb killed the teeth of the center-diff due to a minimum of flex.
aluminium is less stiff then eg. glassfiber, carbonfiber, and it is possible that it is still flexing a little.
Connected to the chassis it also reduces the forces at the center-diff mount. its made of plastic, and it could flex like that very little as well.
Tags
cen matrix
