hagenmi1
01.26.2009, 08:12 PM
Originally Posted by SpEEdyBL View Post
Put it this way. If you gear the 2200 with a 26 tooth and you gear the 2650 with a 22 tooth you will practically get the same results. Not that you would ever gear that high for either motor, but you get the idea. I have a 2650 kv combo on the way that i will be running on up to 5s. It's the same rpm as the 2200 on 6s so I should be fine for my intended use...
...of showing off in the parking lot for 20 minutes straight that is. lol.
That's what I was thinking for the RC8t. It seems with the lower kv you have more room to play with the battery. THX, I'm getting back into since the electric hay day of the RC10 so I'm learning.
