Thanks for the additional clarification. I would be running 5000 mAh or 8000 mAh, so I should be in the clear on that portion.
I take it that it is OK to gear up a 2200 to get speed out of it on 4S in a 1/8 buggy?
I'll take my 2200 off the E-maxx and try it on the buggy. The spur is a 46, what pinion would you recommend to get a good balance on heat/run time/speed?
