02.06.2009, 03:13 PM
Originally Posted by blueb8llz View Post
o ok thanks for the tip. ill just lower it to 100 mah or whatever the lowest is, and ill see if this works. ill report back and see if this was the reason why i lost the punch.
An unbalanced lipo can have serious issues discharging correctly. I would suggest getting it balanced, then not running it too hard for the next few charges. It may go back out of balance if you push it too hard. After a few balance charges it should be good to go. The cell matching of the cheaper packs is not as good, so they will get way out of balance.
You may have to charge it a few times with the setting at .10. Cause the charger will stop charging after 100mah is put in. So it may take a few times of you switching it to charge mode to get it back in balance and charged. May take a day or so... luckily it is a small pack.
