Got Problems!!!
satan'struck
satansbackyard666
satan'struck's Avatar
Got Problems!!! - 02.17.2009, 11:33 PM
OK Jerry2KONE, but just give me sometime...for your info, the ESC is the Speed Passion Silverarrow 1/8 ESC, and the Motor is the Silverarrow 6.5R V10. I did put everything together and did the test run last nite with a HotRacing 21T Pinion Gear and 2 8.4V 4600mAh Eastpower Battery But I found out that the ESC won't take anything that's more than 14.8V so I'll have to get 2 more packs of 7.2V battery(THAT'S REALLY SUCKS BIG TIME!!!) But that's not the MAIN PROBLEM, the problem is that the HotRacing 21T Pinion Gear's Screw is LOOSEI mean after I put that tiny screw in the pinion hole, the tiny screw SWING LIKE HELLLLLLLLLLLL. Now, I've to wait for my friend to order another pinion and that'll take at least 5-10 days from HotRacingOr maybe I should just get other Brand Name Pinion Gear instead!!! Anyway, will keep in touch
P.S. any suggestion about the pinion gear??? I'm using the STOCK SPUR GEAR, 68-TOOTH (0.8 METRIC PITCH)
