Pdelcast
Pdelcast's Avatar
02.24.2009, 05:57 PM
Going out on a limb here, but I would guess it's a ferrous metal.
The stator stacks are made with Japanese source .2mm thickness M19 electrical steel.
The stator design is Steve Neu's 15 series stator.
The windings use 180C Polyimide (Kapton) triple build OFC (oxygen free copper) wire.
The magnets are N38UH minimum material. (the highest quality high temp magnetic material available today.)
The shaft and rotor are made of stainless steel.
The case and end-bells are made from 6061 Aluminum
The bearings are NMB 5x16x5mm CNC quality ABEC bearings.
Anything else you would like to know?
Patrick del Castillo
President, Principle Engineer
