tom255
tom255's Avatar
02.25.2009, 01:27 AM
Originally Posted by teknorc View Post
The motor is still using power to stop. In other words, ESC braking is not free. The 'regenerative' part is that it can recapture small (if not tiny) amounts of power in between the pulses while the braking power is applied. After all, a force is essentially being applied in the opposite direction to bring the car to a stop, just as it would if it was starting from a standstill. This is also why motor brake setups run hotter since the motor is working in both directions. Also, braking force is usually applied more abruptly than while accelerating. AFAIK, a single mechanism (the motor) can't function as a generator and a source of power at the same time. You must use power to brake the car. I'm not an electrical engineer, but I know a few things about physics and the forces that are present and being applied in this scenario simply can't be ignored.
Please correct me if I'm wrong here because our results coincide with jhautz and others that have found mechanical brakes to be more efficient. I'm not arguing that some energy isn't being harnessed or regenerated while braking, I'm saying that it does in fact use power to brake and that the overall net of the system is negative, not positive. Mechanical brakes are obviously using power as well (servo), but compare a servo's energy requirements to a 1/8th brushless motor's requirements and I think the picture becomes clearer.
Actualy Its consume very little not more than couple amps! One guy in russian forum made tests about regenerative brakeng and he did not recorded any noticable power consumption its just shorting motor windings and power force applies through shorting Impulse lenght and opposite phase switching, power consume mostly for FET drivers, brains then braking. MGM, MMM, MM, Schulze, Quark B125. No one regenerated a power, all regenerated power goes for FET heating.
teknorc
02.25.2009, 03:43 AM
Please don't misunderstand. I'm not saying that regenerating isn't happening while braking. There is stored energy in the vehicle to be recaptured. But unless the regeneration or conversion of the stored kinetic energy is 100% efficient, some other energy must be used to stop the car, especially if you are braking hard at high speed. If the conversion was 100% efficient we'd have a perpetual motion machine in our RC cars. Shorted motor resistance is one thing, but we all know how motor brakes can flip a car on it's lid. If shorting was that powerful you wouldn't be able to turn a brushless motor shaft by hand if all three wires were touching each other. This is why I think there is power being applied while braking.
Again, I'm not an electrical engineer, maybe at higher speeds, the shorting becomes more powerful and violent enough to flip the car, not sure. This still doesn't explain why a lot of people are experiencing better run times using mechanical brakes though. I'd like to know for sure from someone who can explain it as well. I've read up on full scale regenerative braking and they all have mechanical brakes to supplement the regenerative brakes for various reasons. One of the reasons cited was to more quickly bring the vehicle to a stop from higher speeds.
So, please, someone explain. If motor braking is indeed free, I have a couple things I want to try to get even more run time
Tekno RC - Performance Parts
Confusing.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Confusing. - 02.25.2009, 04:13 AM
During my 20 years in the Navy I have seen on a couple of occasions where I generator which normally puts out huge amounts of power was turned into a motor when the electrical power flow was reversed accidently. Due to the circuitry involved within the system it was not supposed to happen, but it did.
There is no way that electrical braking is accomplished without using some source of power. That's just a relitive impossibility. But as you stated Patric can probably explain this so we can all understand it.
SUPERMAXX YOUR LIFE.
tom255
tom255's Avatar
02.25.2009, 04:33 AM
Why you cant brake without power, ofcourse you can by just shorting windings on motor or put some capacitance (capacitors) to windings thats it, maybe its not so effective. Maybe you cant change brake force without power source, somehow you just need change chorting impulse lengt and opposite phase switching, that basicaly any ESC do.
I will speak with guy who made a tests on ESC to check Ezrun 150A, does energy recuperation braking works there?
tom255
tom255's Avatar
02.26.2009, 08:40 AM
Ok that guy made a test and still No true regen brakes in ezrun 150.
He made test device/stand. In one side motor spinning other motor which was he tried to brake. Yeah, he noticed regen spikes (Voltage and negativ current) but those spikes are realy short, impulse lenght was 0.002s-0.007s so no true regeneration there, just some spikes thats all.
Seems ezrun 80a make same spikes
George16
Supermaxx
George16's Avatar
02.25.2009, 10:56 AM
The mighty A-gangers did it again .
We lost power to the whole ship during my last deployment due to this. We basically shorted the diesel generator.
Anyway, whatever happens, energy is not lost or destroyed (First Law). However, it is transformed into another form of energy which is basically heat. Now you wonder why motor braking produces a hotter motor compared to mech brakes .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
