Lots of things can kill and ESC like a bad component
alangsam
Lots of things can kill and ESC like a bad component - 02.26.2009, 05:18 PM
This proves the point more than it disproves it. None of those batteries are "high end" batteries and would all be prone to exactly what was discussed in the linked thread. Jim (Tekin Prez) made a couple sensible, descriptive posts in that thread regarding the "potential" pitfalls of lower end batteries. It is a fact. I am not here to call out any specific manufacturer or seller, but many packs do tend to be over rated, inexpensive packs that are popular due to their inflated specs, inflated marketing or low price(or combination of the above). Everything has its place. If your particular setup or driving style, etc. allows you to have great success with your particular "low end or mid range pack that happens to be overrated ", but you aren't anywhere near the particular pack's limits, then you got a good value. If you are pushing things, you will not only notice the performance difference with a good pack, but will be less likely to experience failures.
I am not saying the battery was the cause or wasn't the cause of the failure in the discussion - I don't know the guy, don't know the car and wasn't there. I do agree with the logic regarding the pitfalls of lesser quality cells - particularly in 1/8 brushless applications that tend be very hard on equipment. Maybe the pack was the cause. Maybe it was just one of several factors that caused the failure. Maybe it had nothing to do with the failure at all. It certainly COULD have been a major factor in the failure and the advice to use a quality pack is sound advice.
This debate will continue as there arent the standards we need to compare batteries. One companies 35C is someone elses 25C. Frankly i really like the zippys and they are holding up so well i bought more. When i compare them in my emaxx and erevo with MMM and 2200CastleNeu 19/52 gearing against the Neuenergy packs the Neus get much warmer in the
same application. The truck "appears" to be performing very similarly with the different packs. no I'm not using a tester but i am comparing straight line visual speed and speed on the track. No i havent had them for a year and a 100 cycles so who knows how long they will last. I can tell you my 6000 and 8000ma max amps have puffed in same application but my 35C8400 maxamps packs have not and seem to be a huge improvement over the previous maxamps technology.
It would be nice if someone like MIKE would take samples of the top batts out there and do some real testing for us then we can pay for the performance we really need.
secondly i have had a bad 2075 traxxas steering servo take out a MMM ESC
so their are many variables. If you want to go 60 you are going to break "something" on almost every run.
