Losi ESC smoked in first 3 minutes
fletchoman
Angry Losi ESC smoked in first 3 minutes - 02.28.2009, 06:38 PM
Anybody else having trouble with the Losi 1/8 ESC (LOSB9516)? I was only setup for ~800 watts (5s@40A). I only made a few passes in front of the house when it sputtered and smoked. Can anyone recommend a good reliable ESC that can handle ~6s?
brushlessboy16
brushlessboy16's Avatar
02.28.2009, 07:02 PM
Mamba monster.
e-mike
e-mike's Avatar
02.28.2009, 07:03 PM
Mamba monster.
o yes
D8t on juice!!
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
02.28.2009, 07:10 PM
Mamba monster.
Yep, or be a Guinea Pig and try the Tekin RX8 when that comes out.............soon, so I know if they are any good before I sink more $$ in a new ESC
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
I like it.......I LIKE IT ALOT!!!!!!
fletchoman
02.28.2009, 07:15 PM
Mamba monster.
Seriously??? Has V3 finally worked out the issues?
I was more impressed by the specs on the Losi (160A cont/800A peak). What are the power ratings on the Monster? Are they still using "more than you can handle"?
e-mike
e-mike's Avatar
02.28.2009, 07:29 PM
really the mmm can handle a motor like the neu1527..........dont worrie...buy one....
so how its possible to reach 160amp on 5 cell lipo?????
D8t on juice!!
fletchoman
02.28.2009, 09:07 PM
I would use 5000maH 30C-40C rated Lipos or 6s2p A123...
I like to run my rustler around 800 watts because it is almost a pound lighter but I have a 2000 watt setup that is crazy fast. I find that it best when manufactures define the hardware limits accurately so I can compare and contrast. I feel better pushing 2000 watts when I know the manufacturer rates the hardware beyond 3000 watts...
emaxxnitro
emaxxnitro's Avatar
02.28.2009, 11:55 PM
dude the mmm will not let you down
808E
03.01.2009, 12:12 AM
According to Castle's "Special Projects" page, the MMM is rated for 120A continuous. Now, at first glance, the 160A Losi ESC might seem a better choice, but many ESCs are rated "optimistically". Many I've seen simply add up the current rating of the FETs, and at 25*C. Now, I don't know about you, but even properly cooled setups will NEVER run at 25*C unless in the dead of winter. And FET current rating goes down with temperature, sometimes quite a bit. I haven't spec'd out the MMM, but their HV110 (airplane ESC) is rated at ~200*F - much more realistic. I would imagine they rate all their products in the same realistic way. So, if the Losi ESC is rated 160A @ 25*C, it would be closer to 90-100A at normal running temperatures.
That aside, virtually no setup I have ever seen uses 160A continuous. If it did, even a 10Ah battery would only last 3.75 minutes. Most MT/truggies geared for track use (~35mph) tend to run in the 15-20A average current rating, with peaks up to 7X that (~150A). So as long as the ESC you are looking at can handle the continous and burst value, you're fine.
e-mike
e-mike's Avatar
03.01.2009, 01:55 AM
seriously BrianG youve made a very good explanation again
thanks
D8t on juice!!
pinkpanda3310
pinkpanda3310's Avatar
03.01.2009, 07:45 AM
+1
fletchoman
03.01.2009, 12:16 PM
Agreed on all counts...the question to answer is...are you comfortable running an ESC rated at 120A continuous at bursts approaching ~150A? Losi advertises 800A peak capacity.
03.01.2009, 12:57 PM
Yes, that is fine. The MMM has a ~700a burst rating IIRC.
fletchoman
03.01.2009, 01:30 PM
So why keep it a secret??? I don't see a peak rating on the web.
Continuous: 120A*
*Full throttle continuous operation with cooling airflow
lutach
lutach's Avatar
03.01.2009, 01:35 PM
All the max or burst they state are MOSFET burst rating. If a company says a ESC can do 120 or 160A cont. use that as your burst. Most systems has an avg. of 5 to 20A anyways depending on voltage used. If anyone can find a ESC, battery, motor, wires and connectors used in our R/Cs that can seriously do/handle 100A cont. small enough to fit our R/Cs , please let me know.
