03.01.2009, 08:45 PM
1. 4 is overkill IMO...I run 3s on mine and it flies
2. start w/17 and check temps often...it really depends on how fast you want to go
3. I run 7 10 3...I need to go a tad thicker in the center diff
Even on 3s you will want a bec of some sort..If running a bec, don't forget to remove the RED wire from the rx plug...don't cut it, just remove and secure it out of the way w/tape or hear shrink
Welcome to the forums!
