03.02.2009, 11:46 AM
That was quick, thanks!
I think the Brushless Parameter Conversion is a nice tool but a bit to abstract. In my opinion it would be nice if you could put the dropdown menu from the Top Speed Estimator where you can select the different motors under the Motor KV column. I would also add a scale from 5V to 50V to the Voltage culumn. Then i would set that for example the green range of Feigao motors ist 27k rpm - 33k rpm. And if you now are for example selecting a Feigao 8XL, the voltage controller jumps to around 15V.
I think the Gearing column is just nice how it is now, it depends too much on vehicle type, tire size, estimated speed, the place where you are driving around and so on.
I don't know if it can be realized or if it's worth spending that much of your time on it, but that are just my ideas. I hope you can understand what i'm trying to explain :)
