Countryhick
03.06.2009, 04:54 PM
Originally Posted by jahno30 View Post
I was thinking about using some 6mm carbonfiber, plastic, or plaxiglass flat spacers under the 5xscrews that hold the radio plate to give the additional height required and use plastic spacers on the chassis to possition the battery... I was even considering going with the 6S 4000 http://www.hobbycity.com/hobbycity/s...idproduct=7657 and switch the steering servo to lay on top of the radio tray to get the battery in but using a different kv motor.. My thoughts were the 2650kv combo maybe the better option if I could keep the weight low enough, but not sure if the run time will be any good........what do you think will work out better?
There are 2 ways of thinking about this.
1. Do you want to race it against other gas 1/8ths or
2. Do you plan on just bashing?
If you want to race it I think keep the weight down. The biggest problem with my car is the handling, don't get me wrong it's easy to drive but it is no where near as nimble as it's gas counterparts due to it's weight (almost 2lbs heavier)
If you plan on just bashing go for battery capacity.
With regards to the spacers try your best to find batteries that will fit without modification. I think you will compromise the structural integrity of the car by using spacers.
