03.10.2009, 07:52 AM
Steps
- Remove the centre diff
- Unscrew the 4 screws on the spur gear
- On the reverse now of the spur gear should be the sun gear
- Remove this but pulling with pliers - May take some wiggling
- You will now see a pin which slides out
- Outdrive will now slide out
- Remove the rubber o-ring gently
- Remove the gasket gently
Reverse installation
