I use to run the old modeltech system whitch was the first brushless pretty much to hit the states, it was hacker 8s and shulze 60 amp controller, not a good combo. if you have to use the motor keep your truck as light as you can and order the 9920 warrior controller, run only 10 cells in series and gear 12/72
