MetalMan
MetalMan's Avatar
03.11.2009, 03:07 AM
Originally Posted by himalaya View Post
You really need a sensored design if you want to do some crawling(what Summit was designed for).
Though MMM is the smoothest sensorless BL seen, but sensorless nature is right there, it's not possible to be comparable to sensored BLs in starting smoothness and driveability under extremly low speed. Uncountable start-brake-start-brake on the rock will drive you mad without a rotor position sensor.
Maybe the MM Pro would be a good choice then... Paired with something like a Novak HV 6.5. That motor shouldn't have any problems geared for 30mph, and you could still retain all the adjustability of CC ESCs.
