03.19.2009, 09:01 PM
I would try running the same size tire all the way around. I bet your center diff and motor are getting a workout with the mismatched tires...
I would also drop down a few teeth on the pinion...
I left the Glads. on the front for better turning..but, obviously, it its making things worse. This weekend, I will drop a tooth or 2 and try again
I am also going to try a little thicker center diff fluid to see if that helps as well
