Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.20.2009, 04:25 PM
Originally Posted by warbunny1 View Post
The steering on my 8ight will not return to center. If I turn right and release the wheel, it does not come all the way back to center. the same happens when I turn to the left. I have tried two different servos (both good +200 oz). When I disconnect the servo, the steering moves freely, no binding.
any thoughts?
When you turn the wheels via the servo, do they turn fast like you would expect from a 200 oz torque servo, or do they turn slow? If there is no binding with the servo dissconnected you could have a issue with power to the servo. Try installing an extrernal 6volt receiver pack (if you have one or borrow from a friend) to the receiver and then give it ago, just take out the MMM from the port it is in so you are proving your radio gear only. If that works good, get that MMM looked at, possible BEC fault.
I hope that can help a little and get you on your way to finding the problem
I like it.......I LIKE IT ALOT!!!!!!
