sikeston34m
sikeston34m's Avatar
03.24.2009, 11:04 PM
OK, a little more brainstorming on the tiller attachment idea.
It's gonna be fairly large. Powered by an AXI 4120/14.
If you notice, that is a transmission output shaft. Attach a driveshaft between it and a diff. A diff that resides between a pair of e maxx bulkheads.
There's going to be some lower frame rails involved and a modified upper chassis.
We're going to need the chassis for extra Battery room and a esc to power the AXI.
Our "Tine" speed will be controlled by a servo tester. A potientometer dial for esc speed control. No radio required for the attachment. Infinite "tine" speed control.
Shortened drive shafts for the "tines". We want them as close to the bulkheads as possible.
Now on to the subject of tines. Tires really dig.
How about some of these?
https://www.ssl-stormerhobbies.com/c....pl?pn=MPI1701
2 sets of dual wheels? Hmm..........beadlocks. This makes the tires replaceable while using the same rims.
Tire choice? Hmmmmmm.......how about 4 Paddle Tires?
Then let's build a shroud around the back of it and put a heavy drag bar to smooth out the dirt behind. Hmmm...........
