Go Back   RC-Monster Forums > Support Forums > Team Tekin
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
03.26.2009, 01:40 PM
A-main hobbies says April 1st...
"RX8 Features
Easily Access Programming, Anywhere, Anytime
Drives Sensor/Sensorless Brushless and Brushed Motors
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
PC Interface for Custom Programming
HDAC: High Density Copper Fet Boards
Sensor Plug for Precise Commutation with all Motors
Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Adjustable Drag Brakes
RS-232 Digital Communications Protocol
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
Programming Features
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (7 steps)
Throttle Profiles (7 choices)
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2s, 3s, 4s, 6s, Custom)
Timing Advance when used with Tekin Hotwire
Extensive Tuning via Tekin HotWire PC Interface (sold separately)
Redline T8 Features
CNC Machined 6061 T6 Billet aluminum Ribbed Heatsink Can
Sensored and Sensorless operation.
High Current Solder Tabs
Rebuildable Design
Neodymium Sintered Magnet
Precision Engineered for Maximum Energy Conversion
Dual-Plug Sensor Wire Harness
RX8 Specifications
Controls: Forward/Brake/Reverse
Input Voltage: up to 6S Lipo
Continuous Current: 210 Amps*
BEC: 6.0V/5.0A
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4"
Weight Approx: 2.7oz
T8 Specifications:
KV Rating: 2250
Weight: 14.25oz (404g)
Shaft Dimensions: 19 x 5mm w/flat
Motor Diameter: 1.57” (40mm) / 1.65” (42mm) including fin
Motor Length: 3.0” (76mm)
This product will be in stock on Wednesday, April 01, 2009. "
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
