Jeremy1976
04.06.2009, 10:54 PM
Originally Posted by emaxxracer15 View Post
just took the pack out for a run, i ran it for 25mins and the charger still gives a 4.9 and 4.93 volt warning about the balance voltage being too high. im workin on finding a voltmeter to verify the voltage
Something has to be wrong in your wiring or connections on that pack then. No way after running it 25 minutes would the voltage be the same. Good luck with it and let us know what the end result is.
