squeeforever
squeeforever's Avatar
04.07.2009, 05:47 PM
Discharging it slowly and then charging it will tell you what you want to know, but it won't do any good. When your running it the LVC is most likely tripping as soon as it dips below what you have it set for, but then it will usually rebound back quite a bit (could be ~.5v or more). Discharging it slowly will allow it to go down all the way (most likely something like 3.0 or 3.1v per cell) and it won't rebound back because of the slow discharge isn't gonna make it dip. Make sense?
