Originally Posted by FastXR
Willy:
Did the float charger shut off/go into float mode when you used them on the s/box batteries? If thats the case thats perfect I have a little float charger with a 2/4/6 amp charge rate that I could use.
I run both nitro and brushless so still need the starter box.
Metallover:
Let me know on the 6 amps that would be great!
Thanks guys
On the 6 amps, it's not to comparable to a starter box battery I don't think. I've got 2 12v sealed lead acid batteries in a parralel for a total of 20ah. I am doubting 6a will even stress these sla batteries at all.
