RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.09.2009, 10:23 AM
Originally Posted by Aceldama View Post
In terms of reliability mechanical brakes sure sounds like the wise choice. The ESC and batteries have to deal with those spikes each time you lay on the brakes... the two most expensive and fragile components in the vehicle.
I don't completely agree with this statement, though it has its merits. If you are using a 6s controller on 6s with marginal batteries and have "super hard" brake settings, then this statement can certainly ring true. As a matter of practice, I use a 6s rated esc on 5s max to allow some head room. I also use good batteries and only use enough brakes to slow the car - no instant lockup. I have no reliablity issues.
Any time you push a system to its limits, the margin for error gets smaller, so if you want to push the system this way, then mechanical brakes will widen the error margin. If your setup is comfortably within the limits, reliability is not typically an issue. :)
