hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
04.09.2009, 02:21 PM
Lower kv+ higher voltage = longer runtimes and more efficiency (less heat).... But that depends on your gearing as well...I'm looking to do this exact same thing, I currently run an rc8t on 4s 30c 5000 mah flightmax on the 2200kv MMM combo (42mph on large track 15-20 min run time and ok temps...I have to have a cool down period after back to back packs) but I'm switching to 5s 4500 mah lipos and 1700kv motor for longer runtimes and less heat...but this is all because of the possibility of having 20min+ qual's and mains......
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
04.09.2009, 02:32 PM
if you must run that large of a motor on an MM you are close to or at its limit. the 1600 will tax your MM the least, and go slow as possible on gearing.(30 is an acceptable top speed on a tight track) Also, getting that now will allow you to run 6s when you upgrade to an MMM.
btw: for a four cell pack we say, "4s" not "4c'. It stands for four cells in Series, s for series
