93firebird
04.11.2009, 05:31 PM
I took the truck to my LHS and they said the noise was normal cogging. So I am running with it. I am using a 4s 4000mah lipo for now. the diff is the center diff from the stock genesis tranny with the mxs24 which I think is from the matrix. It's a cnc steel gear with 46t. I am now running a 21t pinion instead of the 19t which seems to have helped with the cogging noise a little. I had to use a die grinder and notch the motor shaft as I couldnt seem to hold on to the pinion gear, it kept flying off even with lock tight. My mounts don't look the greatest but they are functional. Not bad for a saws all and die grinder. Maybe some day my wife will let me get a miter box with a cutoff wheel on it and the cuts can be a little straighter.
