Nothing is worn out in the center diff and nothing binds in the front rear or center diff. Its all loose as a goose. Only thing I havent done is changed the diff oil. When I play with it and get on the gas it unloads the front end and balloons the front tires which is normal. It will also ride a wheelie out so the diff oil cant be too thin. If it was to thin would it cause it to heat up?
