Dafni
Dafni's Avatar
12.16.2005, 05:17 AM
Originally posted by JOHNNYMAXXIMA
The gearing that I am running now is 66/19, and was thinking of going to a 21t pinion. Do you think I should stick with the 19 if I ad the extra cells?
Thanks.
Increasing voltage and gearing at the same time is not a good idea. Check the temps, you might even want to gear down. If I remember correctly, I ran some 9L's on 14 cells with a 16/66.
Originally posted by mack
If I were you I would just try it.:D
What's the worse that good happen.
On 16 cells? The worst? Probably a demagnetized magnet from too much heat.
