Well, I meant the no. of screws the whole chassis of an e-maxx might take. HeHe, does not matter. About the 8 diff spyder..is it for F/R a set or one set for one end?
Nice to meet you!
So the CG of the FLM chassis is not as good as the G-maxx chassis, huh? for speed runs I might need a very low clearance to add more center of gravity to the chassis. This way I might be able to rach higher speeds.
Nice to meet you!
That's where the racer x come's into play. It handles so much better over a normal type suspension. Used with the racer x shock's you can make one sweet handeling truck even with a high cog'd chassis.
Just to make thing's clear, you can easely race this type of chassis's. For a straight line speed run it doesn't make a difference. The lowered battery plate come's into it's own at a track, or if you want to run tight corner's at high speed.
i recommended the gorilla chassis because they are VERY durable and make the truck handle like its on rails. i am not really a fan of the stock type chassis' but if i were to get one i would definately go flm and i recommended the racer-x suspension for one thing is if you bash, the true track rear suspension comes in handy; less things to break. i.e. the rear turbuckles. also, i would suggest the powerstroke shocks. they are probably one of the best.
i admit that the flm is in a league of its own as for durability but i would just prefer a gorillamaxx. even if i only bashed. and for the shocks its just my opinion but i think ue is a bit over rated and expensive although good. i have the powerstrokes and i dont think it gets any better. if you bash i would think 8 prolines would be better than 4 ue because the prolines have the 4 dampers or bypass shocks which help with really big jumps (what i would do if i only bashed still). just my .02 cents.
Over rated? No, they are that good. I love them, best shock's i've ever owned.
Let's put it this way - gmaxx and flm are both good chassis, same with the ue racer x shock's and proline powerstroke's. Whichever you chooise, you won't be dissapointed.
