04.16.2009, 08:47 PM
Mine is done aside from the rear diff.
U will love the truck, just be sure to get cnc knuckles for more steering
Dsm needed
04.16.2009, 09:44 PM
Lookin good Ben!
04.16.2009, 10:35 PM
Looks really good
04.16.2009, 11:11 PM
Wow only took you 7 months to finish (this thread started 9/25) and then you broke it!!! Looking good Ben. Sucks about the tape issue, always use 3m fineline tape for graphics.
I will have some pics up on one of my custom paint jobs this weekend... Heheheh.
04.17.2009, 12:07 AM
Yeah yeah, glad to see your reading my thread. I have broken it a couple of times, in seven months all i went through was 2 front a- ams, a wing mount and this outdrive. not bad to say the least.
i wouldnt say its done yet, kind of an ever changing project.
04.17.2009, 09:51 AM
Already ordered the knuckles!!
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
04.17.2009, 10:10 AM
Very nice. I see you have read up on what the matrix needs
Next you need to shave the C hubs
04.19.2009, 12:40 PM
Got the new drives installed, they are a drop in replacement with a few mods.
First off the pins thta go under the large gear inside the diff are too long and need to be trimmed to fit, Bolt cutters work best- but a dremel would work. Now to the big thing.. The savage uses a dogbone with a larger diameter round end, so the matrix end was swimming in the cup side-to-side. The pin in the cen dogbone fit and was snug but the ball was too small. SInce the ball is not subjected to much load on this axis I came up with a simple fix. Took about 1/4inch rubber tubing and cut it into small-curved strips. and drilled a hole in the center for the dogbone pin to come through.effectively widening the ball end of the bone. then lubricated it with graphite powder. Seems to hold up well with no play at all. the cups are also longer then the stockers and allow for more suspension travel without the bone popping out.
Also got a modded PSU from Eovu87435ds as he is gettin a hyperion ac/dc charger. did a bit of modding to it, cleaned up wiring and mounted the swith internally for a cleaner look.
Dsm needed
04.19.2009, 06:49 PM
Would that be my old power supply  I have a better one now
04.19.2009, 06:58 PM
You do make life hard - Just buy cen outputs...
04.19.2009, 08:43 PM
When I purchased these i didnt have time to wait for an order to come in...
05.04.2009, 07:25 PM
05.04.2009, 07:26 PM
All Clean
RC-Monster Spudgunner
05.04.2009, 07:30 PM
You hose that down?
05.04.2009, 07:35 PM
Hosed, then compressed air then brushed on wd-40 to keep rust at bay/
