RC-Monster Captain
12.17.2005, 09:56 PM
Does the Dace hex adapter suit the ue 6mm cvds?
Nice to meet you!
Yes it does.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Captain
12.17.2005, 09:58 PM
Do you recommend plastic or aluminum rims? why?
Nice to meet you!
12.17.2005, 10:00 PM
I reccomend plastic, why, because they save money, are cheaper to replace, and are alot lighter, in a big crash you are more likely to bend a aluminum rim, as for plastic, it may chip a peice of plastic and still be useable.
Losi 8ight e
RC-Monster Captain
12.17.2005, 10:04 PM
Your mind works in the same dirction mine does. Thaaaaaaaaanks alot, pals. I'll go and make some corrections in my list. I'll talk to you later, Sylvester, PAPA.
Nice to meet you!
12.17.2005, 10:06 PM
No problem captain harlock, show us your list when your done correcting it!
Losi 8ight e
12.18.2005, 01:43 AM
just keep in mind that if you get the dace adapters the go directly over the stock 14mm hex unlike the prolines which eliminate the 14mm hex and just use the stock pin.
RC-Monster Captain
12.18.2005, 06:59 AM
I still need, some fewthings like, aluminum body mounts for the body of the truck. You konw if Mike has them?
Nice to meet you!
RC-Monster Custom
12.18.2005, 07:46 AM
Don't get alum body post, they will destroy the body. Use plastic mount's.
RC-Monster Captain
12.18.2005, 09:40 AM
you're sure about that? how much will the plastic ones cost? what about the rest of the bearings that I need? where are they located and what are their sizes?
Nice to meet you!
12.18.2005, 10:46 AM
DO the dace adapters. they capture and clamp the rim over a larger surface area. Stick with plastic 23mm rims, the wabash rims are the wrong offset, go velocity series either dish or for some bling the velo 6 are nice. For 40 series, the cheyenne has the bling. STay away from the bead locks. to heavy. Tire wise unless you race the mashers are a good all around tire . The crime fighters are sweet especially if you race. I do not like 40mm bowtie , no side wall. Traxxas plastic body mounts remain on my rig. The axle bearings for the 6mm Ue cvd's and the racer x knuckles are 6x16x5 you will need 8. The bearings for the servo saver fro UE are included. Transmission 2@6x12x4mm and 2@5x11x4mm. The bearings for your bulhead / Diff, I need to know what you are going with?
12.18.2005, 11:45 AM
Yeah, as for body mounts you should get plastic, Papa, i think hes gonna use the hybrids or vbs.
Losi 8ight e
RC-Monster Captain
12.18.2005, 12:12 PM
The hybrids coupled with the 8 Spyder diffs should include the bearings needed. The only thing lift is the single speed conversion. How many bearings are supposed to be there inside that conversion?
What are the stock gears I'm going to need after getting the 1/8 diffs and idlers?
Nice to meet you!
12.18.2005, 12:18 PM
4 bearings.
What do you mean with stock gears?
12.18.2005, 01:01 PM
your going to need the plastic second speed gear, the output shaft, the input shaft (modified for the single speed), the idler shaft, and mikes idler, strobe slipper, plastic or derilin ofna spur, stock pressure plates, and i would recommend the sprong kit. you will need all of that and then your flm cnc'd half and the singlespeed conversion. i think thats all for the tranny. not sure what motor mount you wanna run but theres a few better than stock.
