Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
squeeforever
squeeforever's Avatar
12.18.2005, 09:52 PM
candyman doesnt use a center diff, he uses a center slipper from a dominator. a center diff is similar to the front and rear diffs while the center slipper is just a shaft mounted gear with a tension spring to let it slip. diff is the best way to go as it will eliminate the wheelies and will turn quicker and handle much better were as the slipper is the same as a tranny but only a spur on a shaft with a slipper instead of all the other gears in a case. if you dont want a diff a center slipper is the next best thing as they are considerable lighter.
