Yes but.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Yes but. - 05.01.2009, 11:09 PM
Originally Posted by RUSTY XL-5 View Post
I wasn't too sure of the polarity (I had a good assumption) so I made sure I had the polarity right before actually putting the battery "pod" into the remote. That way I couldn't smoke anything. I dont have a volt meter, so I hooked it up to my hyperion and if the polarity was wrong (which it was) it would read "reverse voltage". All I had to do is switch the two power wires around and it works like a charm.
Yes but are you charging the battery pack in the radio, or are you removing the pack and charging it seperately? That is where the problem is. The charging port is wired reverse from regular hookups. From what I understand the plug that goes into the radio is reversed from the normal plug. Normally the plug is + in the center of the plug, where as this port is - in the center of the plug (only for the Spectrum DX3R radio), which is what we are working with here.
SUPERMAXX YOUR LIFE.
