Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.02.2009, 01:43 AM
For the rear, just add Tekno swaybars, and run the thickest bar...that will help a ton!
Also, you should try running a set of ½" off-set wheels, like JConcepts Rulux ½" off-set (17mm hex) or Pro-Line Velocity ½" off-set (23mm hex)...those will also help a ton!
-Chad
PM ME IF YOU HAVE THE BELOW:
