View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
05.06.2009, 05:41 PM
Whats that got to do with the switch though- if you forget to turn the switch off after removng the batts, next time you plug the batts in (without turning the radio on first since due to old age you forgot?) the model would still turn into a run away regardless of there being a switch or not...
Rule #1 in the R/C world is to turn the radio on first, and off last, every time. Funny thing is though I swear the MMM has a built in failsafe of sorts anyway- if I turn the tx off and leave the batts plugged in & esc turned on, the esc leds go to a different color, to indictate 'no signal' and returned the throttle to neutral.
So, switch not required in that sense....
brushlessboy16
brushlessboy16's Avatar
05.06.2009, 09:21 PM
With no signal the esc flashes all three leds and beeps really fast.. or you can just get a dsm receiver which has a failsafe built in. works like a charm
