you're better off with a standard voltage servo in a buggy, plenty of torque and speed. the spektrum passes whatever voltage is input, so the output is dependent on your bec setting.
these high volt servos are aimed at rock crawlers where stalled turning can pull serious amps.
to feed high voltage servos, you either pull the red and black wires and still plug the white(signal) wire into the receiver. then wire the red and black to either a 2s lipo or a dedicated bec for your servo
The rec does not provide the power. What speed control are you using? Or do you have an external bec like the ccbec?
just using a MMM. although thinking of picking up a RX8 if i can find one in stock anywhere. i do have a CCBEC but i havent ever used it for anything and would rather not if it isnt needed.
Jammin SCRT10 Neu 1512 1y
