Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.17.2009, 10:31 AM
Originally Posted by superek4 View Post
hi, do i need to loosen the screw wen i tighten the slip diff? It seems that i strip the screw holding the adjusting ring
If you are stripping the retaining screw on the adjustment nut, you are probably tightening it too much. The thrust bearing removes the twisting force from the nut in use, so it will keep its adjustment pretty well(tested it without a cinching nut, actually). You only need to "snug" the adjustment nut screw to retain the setting. If you use threadlock on it, use a very small amount. You must loosen this screw to make adjustments, and snug it back down when adjustment is complete(this is in the instructions that came with the unit and linked by brushlessboy16). :)
