Originally Posted by Urgeoner
Nice work, u did all the machining urself? what tool do u use if so?
Did all the work myself, with a scroll saw for cutting, drill press for drilling, also chucked an end mill into the drill press for
light milling.
Originally Posted by D8 Driver
great CG, Looks strong.
Thanks
Originally Posted by What's_nitro?
I'm not familiar with Solidworks. How did you go about "syncing" the other components? On that interface, can you select the direction of rotation and add a ratio between the first and second axles, then sync the second gear/pulley set to that second axle?
Originally Posted by anson
Looks good.
Have you checked out the mechanical mates in solidworks? There is an easy option for gearing. You should be able to work it out.
The other components are "locked" together as mates, not synced together.
Sounds like I need to look into mechanical mates and add a ratio.
Thanks guys!
SH Z-Car, Custom Crawler, 8s Savage,
12s XTM XLB 1/7 buggy,
4wd 4-link rear/IFS Pro4 truck,
Custom Hyper 10 Short Course,
Belt-Drive Mammoth ST 1/8 truggy, 4s 17.5 MM Pro HPI Blitz
