I have a further testrun in an asphalt ground.
The 1st speed is fine but a little noisy.
The 2nd speed is quite fast but the truck is easy to roll over with about 1/3~1/2 throttle.
Should I get a heavier rate of springs and heavier wt shock oil or lighten the weight of the truck?
Do you guys have any suggestions to fix the problem?
