Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
05.22.2009, 12:32 PM
Sounds like a good idea on the center driveshafts. The pipe I found had the correct ID, so all I had to do was turn the outside down to the correct OD.
lincpimp came from a bunch of us picking up chicks with an old lincoln towncar that I used to own.
Linc HAPPY BIRTHDAY
05.22.2009, 12:33 PM
Linc HAPPY BIRTHDAY
Thanks! I have had a busy b-day week, but it is all good. I get to build lipos all day tomorrow... Yay....
SpeedAssault
05.28.2009, 04:18 PM
ANybody know of someyone that has adapted 1/5 wheels on 1/8 or 1/10 trucks ?
My way is a machining nightmare
Some new mock ups,
Making 1/5 wheel adaptors, square drive and some 5/16 wheel bolys to screw onto the trxxas shafts
For wheel adaptors, I used a 5/16 hex cap head bolt drill the center , cut the threads off, then Tap to 10/32 to match traxxas axle threas and then drill a 6mm 1/8 depth. Been a PITA as it does not always center, need a real machine
Making a tranny/motor mount out of Delrin, cause I dont have any 3/16 aluminum.
Since the car lifts the front under acceleration with just 3S , 15:1 ratio The motor will be mounted in the front almost centered
ID:	7167   Click image for larger version
ID:	7166   Click image for larger version
SpeedAssault
05.28.2009, 04:22 PM
brightened it up with some yellow
Nice that Castle makes the ESC Black and Yellow, weird the motor is green
Motor will look hot with Silver and Yellow
Any body have a proven way of removing anodize other than phosphoric acid/water mixture ?
maybe I'll just use high temp paint
05.28.2009, 04:27 PM
I would take a scuff pad to the motor and get in all of the little grooves. Then spray light coats of yellow until it iss covered. Let it dry in the sun for a day or so and the take some light grit sandpaper and sand the fins till the al shows back thru. That would look really good with the black endcaps.
