Go Back   RC-Monster Forums > Support Forums > Team Tekin
05.23.2009, 09:35 PM
Do you have a voltmeter? If so unplug the adapter from the esc and plug the lipos into it. Check the voltage at the female plug on the adapter and make sure you get 14.8v or so, and make sure the polarity is correct as well. Visually it looks correct, as long as the deans are correctly installed on the lipos, and you have the pos and neg wire hooked up correctly on the esc.
