05.27.2009, 03:29 PM
I believe they are pretty much a direct fit- plastic rods about 5mm in diameter with holes crossed drilled down their length.
Failing that, look for some plastic rod the same diameter, and drill your own holes using a pillar drill and 1-1.5mm drill bit. Some of this 3906 stuff is getting hard to find nower days...
05.27.2009, 03:32 PM
If for some reason anyone needs the old style towers I have quite a few NIB laying around. I quit using them as I never bothered to open my eyes and see that Lst body posts would work
JoFreak
JoFreak's Avatar
05.27.2009, 03:58 PM
good thing then that the bumper mounts (which are the same on the new maxx) and the body mount posts (for which it seems that there is a replacement from losi) are the only 3906-parts left from the 3906-conversion
anyways, if I got it right, mike still had at least one set of the round posts in stock and put it in my package, which will hopefully get on it's long journey over here
