Freakycrawler
05.31.2009, 09:29 AM
I had the same problem.....to make a long story short contact Thomas at castle.. ext.125.....he walked me through this fix in 10 min. I would have a hard time explaining how to fit it. Basicially, in the installation process you have to rename a file which is causing the problem. As you are installing the program, check each window carefully before you agree/accept anything..look for a window to pop up which allows you to rename a file. That's basically it. However, Thomas knows which window to look for...so I would wait for him.
Ok thanks, i live in The Netherlands so calling castle is a bit un-handy for me
I want to program it because if i rive with a 4600kv motor and the sidewinder sometimes the esc stops working and start cogging if i want to drive.
Could it be broken fets?
Sorry for the off topic but maybe its related
