NoControl
NoControl's Avatar
06.01.2009, 02:57 PM
Its easy I've got the voltage and amp sensors made up for with traxxas connectors, its pretty simple, just pull the esc connector from the rx plug into one of the top 3 in plugs on the mod, use an extension connector to plug into the slot just next to where you hooked up the esc, and run the ext to the rx, plug the volt and amp sens where they are labled making sure all connectors have the black (-) on the outter edge, turn on ur truck or car press the button on the logger and go, when your done just discconnect the batters and hook it to the pc open the software and click download and it'll give data on everything you connected, it comes with 6 digital temp sens, volt, amp, g-force, rpm (for sensored or non sensored) throttle or sterring position sens via the rx, and 1 analog loop temp sens.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
