Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.04.2009, 04:11 PM
If you get an adapter you can hook the two packs up as one and use a normal balance charger. That's what I do... Then hit it with the blinky.
whitrzac
Can't catch this...
whitrzac's Avatar
06.04.2009, 05:24 PM
Yes he did! Apparently his college experimentation stage was quite a bit different than mine... I did live in a coed dorm so I guess I had it made...
college??? I have yet to escape high school...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.04.2009, 09:31 PM
I'd rather keep using my power supply for charging, it's much more flexible and can be controlled from a computer... it also has a nice screen with set volts/amps, and actual output volts/amps/watts. I like it.
And why do they not have balancers at hobbycity?? I don't get this?
zeropointbug
Z-Pinch racer
06.04.2009, 09:55 PM
http://www.rc-monster.com/proddetail...Bsmartbalancer
What about this one? Do I need adapters or anything?
Metallover
Metallover's Avatar
06.05.2009, 12:03 AM
The chargers at hobbycity balance the packs as they charge - as most lipo chargers do. If you buy a new lipo charger, you'll have a built in balancer 99% of the time. I have a balancing charger and a blinky. When it comes off the charger, it is usually perfectly blanced, but I use the blinky to make sure and I use it after runs.
zeropointbug
Z-Pinch racer
06.05.2009, 01:55 PM
http://www.hobbycity.com/hobbycity/s...alance/Charger
What about this one? That, and the 3 cell to 6 cell adapter, that should work right.
http://www.hobbycity.com/hobbycity/s...Chargers_(350W)
This is the power supply I am looking at as well, I thought I would go for a larger psu just to be future proof.
Jabe
06.16.2009, 02:31 PM
Anyone else got these?
This 10awg wire is just over kill... You need right tools to solder that big wire, i used pyropen without any nozzle to heat up bullet connector and that way i was able to solder connectors, without damaging battery with heat.
zeropointbug
Z-Pinch racer
06.16.2009, 04:18 PM
I use a 300watt soldering iron for stuff like that, 5 seconds warm up and it can melt through anything, and it's like you said, easier on things like batts, speed controller, etc. Get in and get out.
zeropointbug
Z-Pinch racer
06.16.2009, 04:21 PM
I think everything should be coming with 10awg wire now IMO. Add that extra edge of voltage holding ability, especially on LV setups of 4s or less. But it just won't heat up and will also act as a heatsink to suck heat away from batts, ESC, or motor. Just my two pennies.
