BADBOY2
06.05.2009, 12:13 AM
any feedbacks for hobby city?any one here got bad experience with them?
scarletboa
scarletboa's Avatar
06.05.2009, 01:56 PM
i have had good experience with hobbycity and i will be buying more from them soon.
badboy2, for your current setup, this is what you should get:
http://www.hobbycity.com/hobbycity/s..._15C_Lipo_Pack
those batteries say they are rated for 15c-20c, but they are mislabled from the factory and are just rebadged flightmax 20c-30c lipos. for $30 and $20, you can't go wrong.
http://www.hobbycity.com/hobbycity/s...lancer/Charger
that charger is the one i have and it is very accurate and is amazing for the low price.
BADBOY2
06.05.2009, 06:39 PM
thanks ,btw 15c discharge is not bad??i was lookin at that charger is it good?how long will it take for that charger to charge the 2s 5000mah ?and u said theyre actually 20c?would that be a problem in charging them?and can u change the connectors to deans?just wanna make sure does that charger have balancer too?thanks!
scarletboa
scarletboa's Avatar
06.05.2009, 07:02 PM
i was looking around in the hobbyking forums and one of the admins stated that that the packs are mislabled and are indeed 20c constant, 30c burst packs. they will be more than enough for your feigao.
the charger has a very good balancer in it and you do not need an external one.
yes, you can cut off the plug and solder some deans plugs on them. that's what i did with my zippy flightmax packs.
it will take about an hour for a full charge on the 2s and about 70-80 mins for a full charge on the 3s pack.
you can either get 2 of the 2s packs, or you can get more power and speed by getting 1 2s pack and 1 3s pack.
BADBOY2
06.05.2009, 07:33 PM
so u can run the 2s and 3s at the same time as long as theyre the same mah?the flightmax are sold out.so the turnigy ones are the option.but wouldnt that be a problem (15c vs 20c) when u charge them ?do uactually have a setting for the C count or it dont matter?
