Urgeoner
Urgeoner's Avatar
06.07.2009, 12:09 PM
Mag-Thanks for your story, I am sorry for your loss as well. My ESC didn't poof, but the battery did and the esc was right next to it
Arct1k-Thanks dude! That's exactly what I am in need of!
Snipin-I don't know, but I was able to get that bad battery out in just enough time so it didn't kep burning the case; The fan still works, just the plastic jailbars on the top of it were burned up pretty bad. It even responds when I try programming it w/the Castle Link!
Byte-Zippy H 3s x2 5000mah
Metallover-Yes, I made the harness to charge both in series, except the balancer was configured wrong the first time and a bit of smoke did come out of the charger, but when I had them hooked up correctly, the charger did recognize all 6 cells...that doesn't sound like I damaged the balancer does it?
All in all, I think that my total loss here would be the battery(ies), the esc case and my brand new body that I painted...I was thinking that alot more was damaged at first. If you can see in the 1st pic of the body, where I sorta cut out that little rectangle on the top? That is where my MMM esc was perched, just atop the rear shock mount...and you can see the badly buned area of the body, so the esc was literally right on top of the fire!
