junkman
06.07.2009, 11:54 PM
same here, getting the dude's mount, and hub, havn't decide to go with the collet adapter, or buy a few new pinions.
06.08.2009, 12:07 AM
If you can do gearing with 25t pinions or less go with the rcm hardened pinions. If you have to run larger than 25t pinions, say you plan to run a low rpm motor or want alot of speed, go with the tdr colleted adapter and Mike's 2 speed 2nd gear screw on pinion, he has them up to 30t.
I have the tdr adapter modded to fit one of my 8mm shaft 1527 motors. Nicely made, just like the rest of his stuff.
