06.12.2009, 05:25 PM
Originally Posted by MetalMan
One flat spot looks a lot cleaner than 2  Though there's nothing wrong with it per se.
Instead of having the shaft turned down to 5mm (maybe I like it thick  ) I'm gonna try to set up my XLB with a 9mm wide plastic spur gear, along with a pinion of matching width.
Pinion is gonna cover the other spot.
BMW M Power!
06.13.2009, 04:02 AM
I just received my 1112 in the mail today. Wow the shaft is hard to turn. This is going to be one torquey motor!
I can't wait to drop it in...too bad the damn mini E-Revo won't be here till Thursday or Friday.
Anyone know if you can trim the wires coming out of a Neu or no?
06.13.2009, 04:12 AM
Strange that it's hard to turn, this 1521 is the easiest to turn of all the 4-pole/slotted motors I've handled. You won't be able to shorten the wires, they're part of the windings.
BMW M Power!
06.13.2009, 04:19 AM
Thanks for the heads up. What connectors should I use? I'm thinking 5.5mm from Mike will be colossal overkill...what about 4mm?
06.13.2009, 04:23 AM
4mm will be plenty! I bet you could even get away with 3.5mm, if that's what the stock ESC uses.
BMW M Power!
06.13.2009, 04:33 AM
I doubt the 3.5mm would cut it. The motor is rated for 600w continuous (1200w peak) on Neu's website. I am going to be running 4S lipo, and at that voltage a peak burst is equal to nearly 100 amps..
