Tips Continued
Shark413
Shark413's Avatar
Tips Continued - 06.13.2009, 07:54 PM
Tip #4
This is an old one but because of the way the shocks rotate they sometimes have a tendancy to unscrew the mounting bolts. The 2.0 buggy uses small set screws to hold the bolt in place, but you can also add a second screw to one of the unused holes to hold the bolt in place. This is the setup on my Losi 2.0 truggy.
Tip #5
Low profile wiring. The stock ESC wires come straight out of the bullets and can interfere with the body on some buggies. But to have them come out at a 90 degree angle just drill out the little hole in the side of the bullet and solder the wired into this hole instead.
Tip #6
Radio antennas can take a beating, the little rubber caps usually don't last very long. A 2.4gig antenna can be much shorter than AM/FM antenna, but they can stil llose there caps. Take some shrink tube and place it over your antenna wire and antenna tube, heat it up and your good to go.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
